Seidelhuber water heater
Fastlane
Fastlane Member Posts: 2
I have an old 52 gal. Seidelhuber Iron and Bronze Works water heater that still works fine.
I,m curious to how old it is and if t-stat parts are available or can be retrofitted. Cat. # 52-3-SGNB
Ser. # D-129993
  • Brad White
    Brad White Member Posts: 2,399
    If you had already not done so,
    I would post this under Domestic Hot Water. I bet Larry Weingarten might have an answer or know where an answer can be had.
    -Ernie White, my Dad
  • Larry Weingarten
    Larry Weingarten Member Posts: 4,010
    Here's something
    Hello:  I found an ad for the heater from 1950.  It's an interesting heater worth maintaining.  Finding parts could be interesting.
    Yours,  Larry
