Trane Steam Radiator
Looking for a supplier to replace a small Trane radiator. I'm in Michigan if that helps.
  • crash2009
    crash2009 Member Posts: 1,478
    Steam contractors
     are difficult to find.  I had to bring in a guy from Detroit.  Pat Girioux from Gross Point did a good job over here in Ann Arbor.  Why do you want to change the existing radiator?  Too hot?  Too cold?  Noisy?  Ugly?  Could you post a picture of it?
  • Phil Yarbrough_2
    Phil Yarbrough_2 Member Posts: 20
    Leaking
    Existing radiator is leaking. Several attempts have been made to repair it. It is a fin coil type. Very small Trane unit
  • crash2009
    Have you tried
     to contact Trane directly for a replacement part?  Then get your local plumber to put it in.
    http://www.trane.com/Commercial/AboutTrane/ContactUs/Feedback.aspx?i=1528
    Steamhead Member Posts: 18,205
    If you strike out there
    you can probably find a suitable replacement from Beacon-Morris or some other convector manufacturer.
    Consulting
