NYC/NY state - seeking a demo site for a new type of vacuum system.
izhadano
Member Posts: 90
This is a continuation of the "Vapor heating system with naturally induced vacuum" thread – I have decided to start a new thread in order to reach more audiences.
A hundred year old single–pipe steam heating system was converted into a vacuum
system which has a naturally induced vacuum. The upgraded system includes an
original Ideal boiler and 6 cast iron radiators which heat an 1100 sq. ft
apartment; the system conversion of such an apartment would cost around $450,
excluding labor (please, see my previous posts for details).
Attached is a graph of the therms per day usage of a steam heating system
before and after the conversion into vacuum system. Savings are in the 9-16%
range. I would expect more savings for a bigger system (with uneven steam
distribution and more overheating).
Comparison is done for winter months with similar average temperatures (this
winter months - after conversion and 2009-2010 -before conversion). Occupation
and heating pattern of apartment didn’t change in last 10 years.
Therms usage is from NGRID bills, average monthly temperatures are from weather
station database.
<span style="text-decoration:underline;">I’m looking for a house or a small/mid-size building with a single–pipe steam heating system in New York or the state of NY.</span> What I plan to do with this building is to convert the heating system into a vacuum system with a naturally induced vacuum and allow this system to be observed in order to prove the savings. Plumbing and automation will be performed by a professional NYC company with a proven record in vacuum heating system implementation.
Changes to the original plumbing will be minimal, most efforts – on system’s
leaks fixing.
<span style="text-decoration:underline;">This is upcoming NYSERDA research project and up to 80% of the conversion</span>
<span style="text-decoration:underline;">cost will be reimbursed to the owner of the building. </span>
Please let me know if you are interested.
Thanks,
Igor
station database.
leaks fixing.
Thanks,
Igor
