Uneven Steam
UnevenSteam
Member Posts: 1
Hi,
I have a 24 unit building with small apts. (efficiencies and 1br's). Its a 1 pipe steam system fired off of oil and we can't seem to get the distribution into some of the apts at any acceptable level. The system is old. Every radiator in the place has had the air vents changed to heat timer vari-valves which have helped us out in the past but we just can't get the steam up in some of them without completely smoking out the rest of the building. Can we add more main stack vents someplace to get better distribution? What's the best move for starters? Unfortunately, like most, we're running on a pretty tight budget at this point.
As a side note, were getting crushed on oil bills because we don't let people get cold, so we're considering a gas conversion. Any thoughts or advice is much appreciated.
get rid of the heat timers
call in a pro to do a venting survey or do one yourself. Your system is not running right and it does not care what your fuel source is. The issue is not in your fuel but in your system. If you are with in a couple hours drive of me call me. If you are in another area use the find a contractor at the top of the page. I am in western Massachusetts.Cost is what you spend , value is what you get.
cell # 413-841-6726
https://heatinghelp.com/find-a-contractor/detail/charles-garrity-plumbing-and-heating0
- 167 Indoor-Air Quality
