proliphix internet based thermostats help
heatmiser
Member Posts: 16
recently was at a customers home and they had purchased a proliphix imt 550 so they could remotely monitor their heating system,as its a second home. the heating system is just a basic airco hot air system,with an old style honeywell 8184g primary control,with a 2 wire thermostat wire.in the single stage wiring diagram it shows three wires rh,w,and g connected,will this thermo. work with this control???the therm side wiring showsthree connections rh,w1 and a common wire.i believe the common is to power the thermo.being that i have no exp. with these thermostats i figured i would post here and see if anyone has used one with this setup .i have included a file with the directions
