Bacharach Fyrite pro 125
Muru
Member Posts: 2
Can i replace the Oxygen sensor of the fyrite pro analyser with city technology 2FO model sensor. if iam not getting the 2FO sensor then which manufacturers oxygen sensor model will match for Fyrite pro 125.?
You got me
I only use the Bacharach sensor. There may be other s that fit the socket, but will they calibrate the same. You do have to calibrate the instrument if you change the sensor.0
