Triangle Tube Challenger Combi
pipe4zen
pipe4zen Member Posts: 108
Any one get their hands one one of these yet?
From what I hear it is a combi type heat exchanger much like a Baxi Luna. It is aluminum
also. I would be concerned about the HX scaling with hard water,well water, treated water, etc.
Other than price point I wonder why they would add this when the Exceellence is a great product.
  • CMadatMe
    CMadatMe Member Posts: 3,086
    edited March 2011
    They Don't Make It
    Its imported from another mfg in Europe. My understanding is that the mfg of this sold a few hundred thousand of them in Europe last year. Have seen it live. Has it's place. Volume condo projects and homes with very small dhw demand. Will only do 3gpm on the domestic on the biggest size. There are 3 different sizes. It's their anwser to the tankless mfgs that push combo dhw/heating at a less expensive price. This is atleast rated as a boiler and has a rated AFUE of 96%.
    Have quoted a project with these. Lit is attached.
  • bob eck
    bob eck Member Posts: 930
    TT Challenger new boiler
    The TT Prestige Solo and Prestige Excellence high efficiency condensing gas boilers with their great SS heat exchanger is a top of the line condensing gas boiler.
    TT new Challenger condensing gas boiler is limited to only three small sizes. Limited DHW output of 3 GPM can run two showers with 1.5 GPM shower heads.
    The Challenger boiler is great for smaller houses with small heating loads and one to two bathrooms with out large tubs or whirlpools where home owners wat to fill them fast that would require a large indirect that can dump water fast.
    If you have hard water you need to have a water softener or you can install what 3M Cuno Auqapure has it is their AP430 filter that coats the copper tubing with a food grade chemical that keeps the unit from building up with lime from hard water. 10 GPM flow rate great to use on domestic coil in oil boilers, on tankless gas water heaters and on the domestic side of the TT Challenger boiler. http://www.aquapure.com/sysproducts/big430.html
    1. Aqua-Pure AP430SS Hot Water System Protector Information:
    2. The Cuno Aqua-Pure AP430SS system installs BEFORE the hot water heater in order to filter the water before it reaches the hot water heater. This helps prevent damage to the hot water heater from scale build-up.
    3. The CUNO Aqua-Pure AP430 Hot Water Filter System comes with the AP431 water filter cartridge and the 3/4" inlet and outlet water pipe connector.
    4. The Aquapure AP430 hot water filter system installs directly on the 3/4" pipe leading into your hot water heater.
    5. The AP430SS will extend the life of your hot water heater or tankless hot water system by stopping scale build-up and corrosion.
    6. The AquaPure AP430 Hot Water System Protector increases the efficiency of hot water systems so they run cleaner. The AP430 helps save money on maintenance costs.
    7. The Aqua-Pure AP430SS scale stopper system features a stainless steel fitting and a consistent dose of Siliphos. Siliphos is a 100% pure food grade scale inhibitor approved by the USDA.
    8. The AP430 filter system binds calcium and magnesium hardness minerals, preventing them from precipitating out of solution and building up on metallic surfaces which helps prevent piping systems from corrosion and inhibits scale build up in hot water heaters & water using appliances.
    I have the Prestige Excellence in my house with cast iron radiators and I love it.
