in floor radiant questions
IZZY
Member Posts: 59
Just had an addition built over my garage (just the shell), will be a bedroom and bathroom. I am planning to put in above the floor radiant, but I want to use panels, not mud, and have a few questions.
- The builder told me to put rosin paper between the layers of subfloor / underlayment. I read somewhere a while back that the rosin paper can let off a smell when the floor is heated. Any truth to that, do I need anything between layers?
- I'm planning to use heat transfer plates. I see a lot of products' literature says you can lay carpet right over this, but I figure that I'll feel this thru the padding so I want to either smooth over the pex with some kind of mud or put a layer of maybe 1/4" plywood on top to smooth the floor out. Any thoughts?
Izzy
Izzy
Questions
- Don't use rosin paper.
- If you have an addition over the garage, you don't need plates and mud. I'd use Uponor QuikTrak:
http://www.uponor-usa.com/Header/Service/For-Professionals/Products/QuickTrack-Floor-Panel-Installation.aspx
or Rehau Raupanel:
http://na.rehau.com/construction/heating...cooling/radiant.heating/raupanel.shtml
on top of your subfloor:8.33 lbs./gal. x 60 min./hr. x 20°ΔT = 10,000 BTU's/hour
Insulate
The heck out of the floor paying particular attention to the rim joist area.
I would use an 1" or 2" of spray foam first to seal things up. Then finish with conventional insulation.
IF your garage will be a conditioned space also may not be as bad. I have owned homes with rooms over garages, and cantilever floors. They are inherently colder areas no matter how well insulated.
I'm not saying this is a bad idea just some tips to do it right from my experience with them.
Gordy0
- 428 Carbon Monoxide Awareness
- 114 Geothermal
