Two Zones-is this the answer? part II
On Jan 11, I posted that question and received good advice. I want to go ahead with using a thermic valve and primary/secondary piping as was recommended.
As this is a single zone, do I run the two circulators in parallel, or is a control
device used to run the two circulators? If so can someone describe the control I need and how it will work in the system?
