4 way Cross fitting off of a 1 pipe steam riser??
Jason Quinn
Member Posts: 96
I am starting an apartment renovation and the unit is on the first floor of a multistory building. The client would like to add a radiator to the existing 1 pipe steam system. The proposed rad will be on the opposite side of the riser as the existing rads. Can I replace the existing steam tee in the riser with a cross fitting to accomplish this without the risk of water hammer or anything else I may not see right now? Thanks in advance for any/all input.
It depends
what size is the riser, and how much radiation is on it?All Steamed Up, Inc.
Consulting0
- 84.7K THE MAIN WALL
- 54 Biomass
- 421 Carbon Monoxide Awareness
- 58 Chimneys & Flues
- 1.8K Domestic Hot Water
- 5K Gas Heating
- 158 Indoor-Air Quality
- 3.2K Oil Heating
- 57 Pipe Deterioration
- 830 Plumbing
- 5.6K Radiant Heating
- 373 Solar
- 14.3K Strictly Steam
- 3.1K Thermostats and Controls
- 55 Water Quality
- 42 Industry Classes
- 83 Job Opportunities
- 24 Recall Announcements
