Mills 20 boilers
Andrew Rudin
Member Posts: 29
Where can I get a spec sheet on the Smith Mills 20 series boilers? I want the fuel input and steam output for one that is 58" high, 44" long and 28.5" wide.
Thanks.
Andy Rudin
Thanks.
Andy Rudin
Mills boiler
I have the data sheet for the Mills 2000, which is the later version of the 20, set up for oil firing without the lower firebox. The 7 section is 44" long and 28.5 " wide. The two top supply tappings are 36 1/8" apart. Ratings are as follows:
Oil GPH 4.45
Gross output 484 MBH
Steam net 1515 Sq. Ft EDR
Does it look like this?
http://www.heatinghelp.com/images/posts/4807/resize_Img_1028.jpg0 -
Ratings
The older coal capable models were rated slightly lower. I have attached a PDF of the boiler ratings catalog from the Wall library. Look under the HB Smith listings for series 200 or 2000. The 7 section was rated at 4.30 GPM and 1275 sq. ft .
http://www.heatinghelp.com/files/articles/950/195.pdf0
