Very Hot Drip connections
Jeff_44
Member Posts: 94
I'm having some balance problems on my one-pipe system. I have the mains well vented with Hoffman's and Gortons. The main vents were piped right at the very end of each main - on a T with the upper side of the T supplying the main vents and the lower directly to the drip connections. Recently as I was checking the system, I noticed that the drip connections were getting hot (very hot) before the main vents could get enough heat to close. Eventually, the main vents close and everything is fine. Am I losing steam back down the drip connections before it can go up into the mains and eventually the radiators?
Any thoughts would be appreciated.
Not steam
you're feeling hot condensate. Nothing wrong here.All Steamed Up, Inc.
Consulting0
- 114 Geothermal
