oil-fired hot air system not blowing air
diarcht
Member Posts: 1
in Oil Heating
we have a buderus oil-fired forced air system - installed about five years ago -- the system is running but no air is coning from registers.
I haven't
seen a Buderus warm air furnace, nor heard of one. Not to say they don't exist, but there are troubleshot the same as any other furnace. Power lacking from a control or board, bad blower motor , a door safety switch, plugged filter, stuck zone dampers if zoned. Could be wiring or anything. Test meters will tell the story0 -
I Think
he has an hydroair system and the coil on the air handler or airhandlers are heated by the buderus boiler,more info please.0 -
to the above list, add
a possible bad zone valve, circulator, or air-bound to above and start checkin. Yes more info, better yet pics!0
