beckett grinding noise
Paulies
Member Posts: 1
in Oil Heating
reset a beckett burner, when it tried to turn on psc motor making noise. is it a bearing, transformer, or burnt out
rounded out coupling
Sounds like the motor/pump drive coupling is gone. There is no band-aid to get it running if that is the case, gotta replace it. If you have a Sid Harvey close by, part# is 155-5. Good luck0
