Wiring Help - Honeywell HZ432 to a SR506
Benjamin
Member Posts: 2
I have a honeywell HZ432 wireless control unit. Looking to wire it to a Taco SR506. I can't find a wiring diagram anywhere and looking for some help. This is a heat only, conventional system.
Search harder
I found how to wire them and also found schematics, need to do a search on Google and type in you model numbers you supplied us with, then you will see the schematics.There was an error rendering this rich post.
