New to hot water...
mchema
Member Posts: 37
I am new to hot water systems due to the fact I have lived with one pipe heat for some time. Currently, my husband and I are looking at a home built in 1910 that's a gravity hot water system. The problem is the house has not had heat for 4 YEARS! Supposedly the system has been drained "properly." I don't know what that means but the huge old boiler must be removed per the gas company. Now my question is how likely would leaking occur in the systems once it's back on line with a new boiler? How brittle do pipes and cast iron get going through extreme hot and cold seasonal changes?
I don't want to get rid of the beautiful direct and indirect rads. But I am worried that things were not properly winterized. Mini duct might have to be an option :(
whoops
Whoops this is the wrong place to post this0 -
Test the system with air first
then try it with water. The pipes do not get brittle from the cold unless the house is in Antarctica.Cost is what you spend , value is what you get.
cell # 413-841-6726
https://heatinghelp.com/find-a-contractor/detail/charles-garrity-plumbing-and-heating0
- 125 Chimneys & Flues
- 19 Recall Announcements
