Need help with sq ft of steam radiators
Gmc310
Member Posts: 2
Ordered a boiler and not sure if it's big enough. I have a 21 inch tall 12 section cast iron radiator. 2- 36" x6" convectors a 46"x6" convector and a 19" x6" convector. Totaling five radiators for a 900sq. Ft. Cape. The measurements on the convectors are without the sheet metal enclosures. I also have 68 linear ft. Of piping to get to the radiators. I did a heat los. Calc and came up with 31k btus of loss and that's what they used to figure on a boiler size along with the other info I listed. We never talked about sq footage of the rads and it has me worried. Thanks for any help anyone can offer. Gary from Boston.
need more info.
ai the 1st rad columns or tubes?... how wide is each.?0 -
Worksheet
Here is what I used to calculate my connected load:
http://www.usboiler.burnham.com/contractors/tool-box-sizing
Good luck!0 -
edr
why did you order boiler before finding out how large of boiler needed0
- 114 Geothermal
