Sharing a LWCO tappng
Timco
Timco Member Posts: 3,040
I have a steamer with two float type LWCOs, and need to add a float type auto fill and meter setup. Can I tee off one of the LWCOs to add this or must it be a LWCO / fill combo unit and just swap out the unit? Customer's maintenance guy left the fill on all night and there was just about 3' of water all the way across a 30x40 boiler room and the 30x30 coal room. What a mess.
  • Charlie from wmass
    Charlie from wmass Member Posts: 4,422
    edited February 2011
    the existing lwco should just wire to
    your auto feeder. why add a probe LWCO? Just use a VXT120 or VXT24 whether it is oil for or gas.
    cell # 413-841-6726
    https://heatinghelp.com/find-a-contractor/detail/charles-garrity-plumbing-and-heating
  • Timco
    Great!
    Here is a pic. I would have to raise the left LWCO to the normal water line, and add a solenoid, correct? There is a normally open set of contacts on the left LWCO. I checked when I stopped over there earlier. Did not even think of this. Is there a kit or do I need a solenoid, relay, and water meter? I think the contacts on the LWCO are low voltage. Is this good practice or is a combo unit more appropriate?
    Tim
  • Ron Jr._3
    Ron Jr._3 Member Posts: 605
    Very nice pipework !
    Did your company do the install Tim ? We see that LWCO on the left used more with condensate pump / receiver tanks . I think it's really called a pump controller . The contacts are more heavy duty and there's more of 'em . Like Charlie said , grab a VXT auto feeder with the built in digital water meter and wire it right in to those NO contacts .
  • Timco
    Thanks!
    Yep, that's my pipework. I should post a pic of the before piping. Sheeeeesh.
    Is there an online source for that feeder? No one here has it. Brand name so I can look for a western states rep? Thanks for the great idea.
  • Timco
    Found it!
    Pex Supply. Perfect. The 120v unit came right up. Thanks!
