weird question
If water is sitting in a u-bend almost like a trap found in a sink what would happen if 10 lbs of steam struck it. Would the water act as a dead end would all of the steam condense, or would the steam just slam it through. Also is it possible that the steam would slam it through but in the process condense to water and take the place of the original condensate.
  • Dave in QCA
    Dave in QCA Member Posts: 1,808
    10 psi steam and a trap
    It really depends on what is behind that ubend trap.  Is it vented, or otherwise at atmospheric pressure?  How deep is the ubent?  Is the pressure consistently at 10 psi.
    Can you expain just a little bit more what you are talking about?
    Dave in Quad Cities, America
    http://grandviewdavenport.com
  • will smith_4
    will smith_4 Member Posts: 259
    Not so weird
    If you have 10# on one side of anything, what will happen will depend on the pressure that's on the other side-the pressure will do everything it can to equalize.
