Steam Heater Help
JCDub
Member Posts: 1
I'm fairly new to this steam stuff and being in down in south texas we don't have much of it. Came across a problem and hoping somebody can help me out. I have 4 steam heaters we have to replace in a warehouse that are probably older than I am. The only info I can find on them is "National - U.S., model no: 74-B14CK3Z6AG, serial no: Y1982HH, Crane Co. 1 1/2" inlet and outlet. I can't find any specs on it anywhere online or through our local heating companies. Basically its a big radiator that steams runs through with a little blower on the back side. I have talked to everybody I can think of trying to find a suitable replacement for all 4 of them with no luck. Any help would be much appreciated. Thanks.
Modine?
You might try Modine as they have warehouse steam radiators which are seem similar to the ones you need to replace.
- Rod
http://www1.modine.com/publications/litnav.php?c1=CHVAC%26R&c2=Modine&c3=01+-+Steam%2FHot+Water+Unit+Heaters0
- 86.7K THE MAIN WALL
- 56 Biomass
- 102 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 158 Indoor-Air Quality
- 3.5K Oil Heating
- 68 Pipe Deterioration
- 935 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
