half of the pipes in basement not getting steam
mikest315
Member Posts: 1
Thank you everybody who participates in this forum. I just bought an old house and I have learned a lot from all of you. When I first bought my house a month ago, all the radiators worked. However, the radiators in the back of the house no longer work. I went in the basement, and discovered one of the pipes leading to those radiators is cold. This pipe has a vent on the top. I tried taking a picture but it may be tough to see. Should replacing this vent solve the problem?
Thanks, Mike
Thanks, Mike
lazy steam
you can turn the system off, and when cool, remove the vent, and re-fire. when steam comes out the vent opening, you know that the pipe has no obstructions in it, such as a sag, or water puddle, preventing the air from escaping so the steam can move. in this case, you need a new vent. be ready to turn the boiler off as soon as you see steam.
if you see no steam, then check the pitch of the pipe with a level. in a complicated pipe run, it helps to put masking tape on the pipe, withe arrows marking the direction of downward slope. on my system, i had an area where the arrows were pointing towards each other! it helped that these areas of dry return had not yet been insulated, but if yours are, then maybe a nail at each end of the level will pierce the insulation enough to give you a reading.--nbc0
- 86.7K THE MAIN WALL
- 56 Biomass
- 102 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 158 Indoor-Air Quality
- 3.5K Oil Heating
- 68 Pipe Deterioration
- 935 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
