Radiant heat boiler running time ?
mike parnell
Member Posts: 42
Hi Guys,,
The new house Ive built approx 2800 sf.with oil fired radiant heat in concrete slabs on all floors, I have a Tempcast Masonry Fireplace in the center of the house. The radiant was installed by me,no heatloss calcs,tried but couldnt figure out 28' high living room ceilings.This was my second heating project, learned alot right here at heating help .com, I wired an outlet to my boiler power switch,so that when the boiler fires this outlet is powered, I plug in a analog clock,and the last few real cold days here in Mass,the boiler only ran 2-1/2-3 hours in a 24 hour period, this while the Tempcast masonrt heater was burning, Im real happy with those numbers, with oil prices still climbing,, Does this sound good ??
Thanks ,, Mike in Hopkinton
boiler run time
too many variables to consider and too little information, Mike but here is a question or two for you: Are you comfortable in the house ? If so, what's the issue? If not, there may be an issue. A lot of factors go into calculating boiler demand and project run time/fuel usage so we would be hard pressed to say if you have an issue with information provided. IF you feel it is really problem, bring in a heating expert to help you evaluate the system's performance.0
- 117.5K All Categories
- 82.8K THE MAIN WALL
- 2.7K A-C, Heat Pumps & Refrigeration
- 43 Biomass
- 402 Carbon Monoxide Awareness
- 8 Chimneys & Flues
- 1.6K Domestic Hot Water
- 4.3K Gas Heating
- 107 Geothermal
- 148 Indoor-Air Quality
- 2.7K Oil Heating
- 45 Pipe Deterioration
- 679 Plumbing
- 4.8K Radiant Heating
- 353 Solar
- 13.3K Strictly Steam
- 2.9K Thermostats and Controls
- 48 Water Quality
- 31 Industry Classes
- 65 Job Opportunities
- 11 Recall Announcements
