Louder
lp123
Member Posts: 1
Guys ,
Seems after tune up my boiler sounds louder when its firing .
What would cause this?
Thanks,
Linda
Thanks,
Linda
louder boiler
Seems and is are two different things but maybe it was very dirty and the soot helped insulated the sound ???? Actually it's more likely a change in the settings. If the technician adjusted the burner air settings or the draft differently than it was, you could experience a change in the sound level, but I suspect it would be minimal. If it is really louder when it comes on, call the tech back as you may be experiencing delayed ignition.0 -
also
compare nozzle size/spray angle/spray pattern to what was in it prior to what it is now. Also depending on the unit, target wall/chamber condition and or movement0
