Leaking Steam Convector - Please advise...
MeisterD
Member Posts: 1
Hello -
I am looking to purchase an 1800 sq. ft. circa-1933 home with what I believe is a Dunham steam/vapor system. The house has mainly radiators that are recessed into the walls (is that good or bad?) and convectors built into the walls below all the 1st floor windows. One convector appears to be leaking - it hisses steam and is dripping condensate onto the wood floor - the valves and steam traps are located in the basement directly below the units. Is it difficult to find replacement convectors? I assume the wall has to be demo'd in order to reach the fittings? I am new to steam as my current abode has a scorched air system. Any guidance is much appreciated!
Need pictures
Hi- If possible a few pictures would be a big help! Most steam things are fixable.
- Rod0
- 120 Geothermal
