New radiator fountain after new boiler
LPB
LPB Member Posts: 3
  • Rod
    Rod Posts: 2,067
    Need New Piping
    Hi - It always amazes me why some installers blatantly ignore the Installation manual.
    There are half a dozen things wrong with this install.
    - Rod
  • LPB
    LPB Member Posts: 3
    Manual
    Its funny you should say manual. It was never even taken out of the folder!
    I told the manager of the guy who installed this bolier that there was a problem with the piping and he said (GET READY) "Hmmmm are you sure well did he pipe it like the old one was piped?"
  • BobC
    BobC Member Posts: 5,568
    A waste of time and effort
    Hopefully you sill owe this knucklehead some money!
    If a steam boiler isn't piped per the install manual it is not going to work. there is not one thing with that install that is correct. If he balks at repiping it correctly (in threaded steel pipe) per the install manual call up the boiler manufacturer and ask them to twist his arm.
    Bob
    3PSI gauge
  • LPB
    LPB Member Posts: 3
    service call
    I am a service tech from another company. I was there to find out why the new boiler wasnt working. Thank god I'm not the home owner.
  • nicholas bonham-carter
    in cases like this
    the mfg's rep should be able to help by pointing out from the source of authority that it is wrong [at least i know that our local area peerless rep would, and has].--nbc
