CLEANING THE COIL
RICK JAMES
Member Posts: 11
Any one ever cleaned the coil on a heat trans ssu superstore indrect ?? alittle help
no I have not.
the coil is not removable in that is it? If you need to I guess 5 gallons of "sizzle" and drain the tank dry and pour it in through the Vacuum breaker port with a funnel. then let it soay and flush it really well.Cost is what you spend , value is what you get.
cell # 413-841-6726
https://heatinghelp.com/find-a-contractor/detail/charles-garrity-plumbing-and-heating0
- 119 Geothermal
- 394 Solar
