help finding old radiators
MikeDaugherty
Member Posts: 6
i have some corto style radiators that were leaking. so we took them
apart to change out gaskets between each section. we used o rings over
top of reverse thread nipples. does anyone know or have some
suggestions as to a better sealing method. the o rings would tear
creating leaks. thank you. these were originally steam and were
switched to hot water these have five tubes. does anyone know or may
have some old radiators that they could direct me toward. i could
really use some help with this. thank you
This post was edited by an admin on January 19, 2011 3:18 PM.
Finding old radiators
Hi Mike,
Where are you located?
Finding old C/I radiators takes patience. Lucky for you the 5 tube, Corto style was popular and is easier to find than many other styles.
I would look in local salvage yards and on Craigslist in your area.
Good Luck!
Gwen HealyThere was an error rendering this rich post.
Brass Knob Back Doors Warehouse in DC
If you're near DC, these guys have a bunch (although I believe they are in the process of closing): http://www.thebrassknob.com/backdoors/catalog.cfm?category=90 -
location
im located in pacific grove California.0 -
Re: refurbishing radiators
Get a hold of the company below. I talked to them about the process several years ago and they will know what type of gasket to use. They restore/rebuild/ resize all kinds. Good luck
http://www.theoldradiatorcompany.co.uk/0 -
Have you checked here?
http://www.heatinghelp.com/article/9/Virtual-Trade-Show/236/Searching-for-Old-Radiators
It pays to wander off the Wall.Retired and loving it.0
- 167 Indoor-Air Quality
