Hooking up a propane furnace
Dodge
Member Posts: 3
I have a few questions about installing a propane furnace in my shop ; the furnace has an oval shape pipe on the exhaust , should I use the wood stove type pipe for venting this ? How hot will it get? , its 10 feet before it goes thru the tin roof and insullation , should I use insullated pipe to go thru the tin ? Also is there a flexable gas line avaliable to use for the lp gas , its bout 20 feet to the tank or would I be better off useing copper ? Thanks
Venting furnace
Around pipe squeezed will make your oval, depending on size I would use 24 or 26 ga. Then go to b- vent, the b-vent needs 1" clearance where it goes thru anything combustible. Soft copper and flare fittings for the gas line.0
- 87.1K THE MAIN WALL
- 58 Biomass
- 113 Chimneys & Flues
- 5.7K Gas Heating
- 110 Geothermal
- 161 Indoor-Air Quality
- 70 Pipe Deterioration
- 998 Plumbing
- 6.3K Radiant Heating
- 391 Solar
- 15.4K Strictly Steam
- 55 Water Quality
- 44 Industry Classes
- 48 Job Opportunities
