Gas Boiler recieves call for heat, but does not fire up.
Shuttle
Member Posts: 24
He guys, am a homeowner. and i realized yesterday my boiler would not light as the thermostat called for heat. (The damper twisted, and it did not light up) I flicked the emergency shutoff switch to see if the pilot was lit, It was on, so I decided to switch emergency cutoff back to "on". This morning I had the same problem, soI flickedthe switch on and off (it did the trick) Rightnow, nothing works! No dampner noise, no start up, no Heat!!
What could be the problem??
Call a Pro
Hi- You need to call in a pro. Homeowners (including me) don't have the experience or test equipment to work on burners.
- Rod0 -
It just fired up!
Hi, I lightly tapped the damper area with a wrench, then I heard the "damper Twist" and it lit up! could it be a "dirty flute?"0 -
NOT A PRO
I AM NOT A PRO, but i've had similar experience. I called in a plumber and they replaced the "spill switch" which was located right near the vent damper on the bottom...
perhaps this is the problem.0 -
Fired Up again
Well, I took the flue (exhaust) pipe apart and to my surprise it was clean, I put it back together and The boiler still has trouble starting. I just discovered that by lightly "tapping" the pigtail on the pressuretrol It starts up. (I assume the pigtail needs a cleaning!!) Can anyone tell me how to get a wench in there so I can remove the Pigtail? It seems to small a hole!)0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 48 Industry Classes
- 15 Recall Announcements
