Water hammer issue
daneheat
Member Posts: 8
I have 2 zone valves on the 1st floor on 1 thermostat. One zone valve for the 2nd floor on its own thermostat. When the 2nd floor thermostat is satisfied there is a bad water hammer. There are 2 Erie zone valves and 1 Caleffi zone valve. The valves are all installed in the correct direction. It was recommened to install a pressure-bypass valve.
springs
the erie zone valve is just like a honeywell you can remove 1 of the springs that shuts valve when unpowered this will normally lessen or stop bang0 -
What spring or springs are you talking about
Checked out the Erie zone valve and can only find 1 big spring. Please let me no which spring you are looking at. Thanks0 -
Is the valve
backwards?Cost is what you spend , value is what you get.
cell # 413-841-6726
Erie Z/V's
are no good in my book. They are probably the cause. I have had end switch issues with some. Sounds like the circ is still pushing when the valve is closing or closed.0 -
erie
Sounds like an end switch issue. I have been there with these valves. They are poor knock offs of a Honeywell0 -
double post
oops0
- 87.4K THE MAIN WALL
- 121 Chimneys & Flues
- 15.8K Strictly Steam
