Converting a hot water baseboard to hw convector
vinudev_LINY
Member Posts: 1
Hi! I am planning to have our basement finished soon. We currently have a single hot water baseboard in the small section that's finished. I would like to expand the system so that the entire basement is heated. However, I cannot use a baseboard system as I would like to have closets and shelves line the perimeter. Is it possible to convert the hot water baseboard to a hot water convector system? We have something that looks like the Beacon Morris convectors on our main floor. I am wondering if such a system is still available. I have only seen baseboards around here(Long Island, NY). Or are there other options that will work in this situation?
Thanks in advance.
vinudev
Thanks in advance.
vinudev
Many Options
You have a lot of choices when it comes to convectors and a local heating contractor will have more information. Here are a couple of popular brands:
http://www.runtalnorthamerica.com/
http://www.mysoninc.com/store.asp?pid=167938.33 lbs./gal. x 60 min./hr. x 20°ΔT = 10,000 BTU's/hour
Two btu per sq ft for degree difference for a slab0
- 87.8K THE MAIN WALL
- 129 Chimneys & Flues
