Cracked Boiler?
gibson
Member Posts: 15
I have a 25 year old, one-pipe, oil-fired steam boiler. There are new air vents on the radiators, new main vents, the valves on the radiators were recently repacked, and there are no underground returns. But, I am still losing about 1 quart of water per day- only on cold days. So where is the steam escaping?
I visually inspected the chimney and saw no steam escaping while the boiler is firing. I haven't flooded the boiler yet (to test for cracks) as the weather won't permit. However, I stuck a small mirror (on a stick) in the exhaust pipe leading to the chimney. The mirror got steamed up. Do I have a cracked boiler?
Leak?
That steamed mirror is suspicious on an oil fired system. It might indicate a very small hole above the waterline. It makes sense it would more noticeably loose water on cold days.
Make sure you check all the piping just to make sure you don't have a slow leak somewhere, steam leaks can be tough to find.
3PSI gauge0 -
not so fast
a steamed up mirror could be flue gas condensation....still suspicious but not a certain test1-pipe Homeowner - Queens, NYC
NEW: SlantFin Intrepid TR-30 + Tankless + Riello 40-F5 @ 0.85gph | OLD: Fitzgibbons 402 boiler + Beckett "SR" Oil Gun @ 1.75gph
installed: 0-20oz/si gauge | vaporstat | hour-meter | gortons on all rads | 1pc G#2 + 1pc G#1 on each of 2 mains
Connected EDR load: 371 sf venting load: 2.95cfm vent capacity: 4.62cfm
my NEW system pics | my OLD system pics0 -
yeah, not so fast
H2O is a byproduct of combustion.0
- 120 Geothermal
- 394 Solar
