Circle Combvustion Sysyem/ Calortechnica Boiler
ChrisGNH
Member Posts: 1
I have a Circle Combustion oil-fired hot water heating system, installed in 1988.This unit features a Calortechnica boiler with a Riello burner, The boiler is a European-designed unit, doghouse-shaped with three passes.
When my technician came to do routine service, he could not find the access port/door for cleaning the boiler.
Does anyone have any info on this system ( literature, drawings, etc) and can anyone tell me how this unit is accessed? I was told that there is a sheet-metal screen clipped to the front of the boiler. Once removed, there is a cast iron door that is latched to the boiler that can be opened.Is this true?
Thanks.
Thanks.
servicing the circle
Good boiler. There are removable jacket panels on the front and back of the boiler. The flue pipe most be removed and the burner should also be removed. The bolts holding the clean out covers will be obvious. The front and back both have two covers, top and bottom. The tech should have on hand some water glass and glass rope to replace the gaskets that are likely torn and or missing.
Good boiler. Did I mention that?
peace
Matthew0 -
The only time.....
I saw one of those was in stratham, nh. Looks like a decent unit (3 pass) the install was a bit funny as it was a LONG run to the power vent. Should be a easy clean. Very similar to Pensotti.0
- 86.7K THE MAIN WALL
- 56 Biomass
- 105 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 159 Indoor-Air Quality
- 69 Pipe Deterioration
- 948 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
