Circa of Am. Stand. wall unit convector/ loop? SW200 / JV-1
jackjackjack
Hi- Hoping someone can tell me the general age / year(s) manufacture of an *American Radiator & Standard Sanitary Corp. "Remoteair" wall unit- model # SW200, JV-1 Series*. Also seeking a possible source for replacement parts and covers?
Not sure if it would be called primarily a convector, or a loop design (cold water during the summer & hot water during the winter). I'd call it a convector-looper-blower design :)
It's attached to copper pipes (might've been switched out from lead) and a powered fan/blower under the convector unit, and a condensation catch pan between the blower and convector. It was obv. installed during original construction, building age might be from 1940's up. In D.C. and it seems to be a popular unit for apt. buildings here.
That name...
... was used while the two companies merged. I found this on the American Standard web site:
"History
Before American Standard, there was the
Standard Sanitary Manufacturing Company. It was founded in 1875, and
merged with several other small plumbing manufacturers in 1899 to form
the Standard Sanitary Manufacturing Company. Standard Sanitary pioneered
many of the plumbing product improvements introduced in the early part
of this century including the one-piece toilet, built-in tubs,
combination faucets (which mix hot and cold water to deliver tempered
water) and tarnish-proof, corrosion-proof chrome finishes for brass
fittings. By 1929, Standard had become the world's largest producer of
bathroom fixtures.
That same year, the Standard Sanitary Corporation merged with
American Radiator Company to form the American Radiator and Standard
Sanitary Corporation. The corporation adopted the name "American
Standard" in 1967."
I'd have guessed a smaller window, but this gives you 1929 to 1967.
Yours, Larry
ps. This site might be useful
http://www.hvacsolutionsdirect.com/products/Replacement-PTAC-Units/Islandaire-Direct-Replacement-PTAC-Units/American-Standard-3/AMERICAN-STANDARD-REMOTAIRE-PTAC-Type-40-SKU1141.html0 -
Yup.
Thanks for the fyi Larry- I saw that the merger was in 1929, but didn't know the 1967 date. You're right, and I included the full name to try help. Problem with the apt buildings around here, a bunch of construction came in the mid 40's, and then a bunch more came in the 60's... the whole federal gov't thing.
So these things could be as old as 70+ years, or as new as 35- years (ok, not very new, but). Did a ton of Google searches, no luck.
Oh, it has two small hatches on the top (either side of the top vent). One for a 4-place switch (off to high blower) and the other for stop valves access.0 -
Wall Units:
These were/are popular in commercial type applications. Often known as "Modine" type heaters. The multispeed fan switch let you dial in the output of the unit. American Standard was never a big player in this market. I have never seen one in place that wasn't older than dirt. Modine and one other ( I can't remember the name) were far more popular than Am. Std. Am. Std just couldn't keep up with other forward thinking companies.
I doubt that you could find any parts for them other than motors. Replacement is the only option.0
- 87.8K THE MAIN WALL
- 129 Chimneys & Flues
- 123 Geothermal
