I can't find the EDR values anywhere
Steve Fontas
Member Posts: 26
I'm sizing up a new boiler for a 10 unit prewar building in NYC. They have these old recessed convectors that I can't find EDR values for. I even looked in Dan's book. Here's a photo of each end of a convector. This one was 8" wide, 6" deep by 60" long. The others in the building are the same style, but only 2" high, 6" deep and varying lengths, I'm including a photo of one of those too.
Right now the building has a boiler I believe might be oversized but I need to figure out these EDRs first. In the meantime I have been using values for Sterling convectors..
Thanks guys...
Thanks guys...
cabinet dimensions affect EDR on a convector
We will also need the dimensions of the cabinet, not just the fin tube element.
Need to know the overall width, depth, and height of the convector unit. Then comparing to the nearest should enable some of the pros on here to come up with a fairly accurate number.Dave in Quad Cities, America
http://grandviewdavenport.com0 -
That would be great
But I didn't think You guys would give me EDRs for 25 different units. I was kind of looking for a place t find them myself. In any case, they are fully recessed, 24" enclosures. Here's a spreadsheet.There was an error rendering this rich post.
Looks like Governale Bros. International Convectors
Lookin your copy of EDR, page 215-217. Look especially at the image on pg 216, sure looks like the element in your first 2 images. They were manufactured in New York, so makes a lot of sense that may be what you have.
I don't know whether your 3rd image relates to pg 217, or whether it may be a replacement element.
Hope this helps.Dave in Quad Cities, America
Sweet
Thanks Dave. I'll look. How did I miss that?There was an error rendering this rich post.
It might be them
Guess, I'll just have to go with those. Thanks again, Dave.There was an error rendering this rich post.
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 848 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
