New Excel question jpf321
Maine Vent
Member Posts: 130
1. I have long main of 35' X 2" dia, and a short main of 4' X 2". How do
I figure the sq ft EDR of these pipes for the main vent
recommendations?
2. I have the Balance your system pdf from Gerry, I understand the time
to vent for the main vent times. As I work the spreadsheet with the time
to vent for the radiators each time I make a change to the time
variable it changes the rad vent recommendation. Here is the question,
how do time the vent time to each separate radiator. Example, start of
boiler to a hot rad. valve, or when main vent gets hot then time to each
rad. valve, or do I pull the rad. vents and time to full heated
radiator? Thanks for photos and all your research into steam heat.
recommendations?
Weil McLean SGO4, Riello Gas Burner
404 sq ft EDR
Old Burnham V8 Removal
404 sq ft EDR
- 120 Geothermal
- 169 Indoor-Air Quality
