water level dropping
there is no visible "white clouds" coming out of the chimney, don;t really sense a change in the humidity of the boiler room section of the basement...I am thinking the leak is in a crawl space since I have a cold radiator that comes off a riser from the crawl space,. Does this make sense? I have closed off the valve at the radiator and am hoping that this will slow the water loss.
dan
