O2 barrier PEX or not?
mtman5821
Member Posts: 1
I have some existing pipe in my basement and garage slabs. The tubing is was installed around 2000-2001 and was part of an open-loop staple-up radiant 'kit' that was purchased, but not installed. I am trying to determine if this is O2 barrier tubing or not. I have read that 'shiny' pipe is usually O2 barrier PEX. this tubing has a glossy type finish, but the markings on the tubing are as follows:
ASTM F876/877
CSA 137.5-NES
PP101-UPC HOT/COLD POTABLE WATER
I compared it to the Non-barrier Vanguard Vanex tubing in my potable water system and it is slightly more shiny.
Thanks!
ASTM F876/877
CSA 137.5-NES
Thanks!
my first guess is not...
Unless it says somewhere DIN 4726, or EVOH...
ASTM F876/877 and CSA 137.5 are both potable water specs for pex. I don't know what pp101 signifies.There was an error rendering this rich post.
- 87.8K THE MAIN WALL
- 130 Chimneys & Flues
