Monoflow tee system
Donald Lebnikoff
Member Posts: 9
I have a customer with two story mono-flow system. The system is all one zone. The customer is putting an addition on the house and would like to add a separate zone off the boiler. My concern is that the separate zone might create a flow issue when both zone are calling for heat. Or do i tell them to re-pipe the whole the system in primary- secondary or any other piping options. Any input would be greatly appreciated.
Why not
leave the existing monoflow zone on it's own pump and add another pump for the new zone? I'd pipe the new zone 2-pipe instead of monoflow, no?
And if the new addition is a small heating load, definately add primary-secondary to keep the boiler happy when only the smaller zone is calling for heat.8.33 lbs./gal. x 60 min./hr. x 20°ΔT = 10,000 BTU's/hour
we have
had good sucess using Dans book HOW COME. if you can pipe the new zone right from the boiler and you have a good air seperator you should be OK.
lets see what others have to say0 -
Monoflow systems:
I've seen more mixed monoflow/ series loop systems in older houses where I work than any other piping systems around.
Just make the new zone a separate zone.
I've never seen one not work. The biggest problem I ever saw with them is that the added circulator was wired direct and didn't start the burner.0
- 86.7K THE MAIN WALL
- 56 Biomass
- 105 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 159 Indoor-Air Quality
- 69 Pipe Deterioration
- 948 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
