just me
moishe
Member Posts: 1
i have an old home with large ( 2 1/2 inch) hot water pipes in the basement. I cant seem to find a large enuff insulated tube to fit them. What has the highest R value and best way to insulate them?
This link is from a few weeks ago.
Inside it are some other links to insulation manufacturers. You can get pipe insulation in 3' lengths and in various r-values. There is also a link to get elbows and T's. This type of insulation might be overkill for just a water pipe though. I have not seen the closed foam in 2-1/2".
http://www.heatinghelp.com/forum-thread/132995/What-type-of-pipe-insulation-should-be-used-on-the-near-boiler-piping#p12069610 -
73 year old one pipe system with original American standard boiler, oil fired becket, 2 inch steel pipe main, 100 feet long, with 8 radiators above.0
- 120 Geothermal
- 394 Solar
