radiator enclosures
       I have some 3/4 inch thick wood radiator enclosures with perforated sheet metal fronts and solid top and sides.  Would it be worth the effort to add hinges to the top so that it can be opened to say a 45 degree angle to allow the heated air to escape more easily?  Would it be even better to replace the perforated sheet metal fronts with shutters to direct the heated air out?  Sizzlaw.
