Broomell reciever leaking steam
mike cipollone_2
Member Posts: 7
We have a Broomell system that suddenly started leaking steam out of top of the reciever through the valve that comes from the stean header. How do you get it to stop? Mike
here is the manual
I don't know Mike, but here is the manual
http://www.heatinghelp.com/files/articles/1383/54.pdf
There is a lot more info on the Broomel there too.
http://www.heatinghelp.com/article-categories/163/Older-Steam-Heating-Systems0 -
What pressure are you running?
That receiver has a safety valve in it that opens at something like 7 ounces of pressure. This system should have a Vaporstat instead of a Pressuretrol to control the boiler pressure. Maybe the pigtail under the Vaporstat is plugged?All Steamed Up, Inc.
Consulting0
- 120 Geothermal
- 394 Solar
