Heating Valves
Gordy
Member Posts: 9,546
Does any one know where I can get this type of balance valve for 3/8" copper pipe size. Seems the smallest I can find is 1/2"
Or can these be rebuilt? Got a little seepage on some of them around the stem.
I tried to back out the retainer nut to see if I can pull the vavle out but once the nut was removed the valve would not pull out.
Thanks Tim
But the smallest is 1/2". I need 3/8"0 -
Here is one from oventrope
[color=#0066cc][u]solder type, straight, 3/8" x 12 mm[/u][/color][u][color=#0066cc]1090951[/color][/u] 1,7 These are the allen type stop valve that may work very well for you. Cap over adjuster. Use allen wrench. Put a female adapter on the spud. ????
That's just a ball valve with a slotted stem
I was looking for something in 1/2" awhile ago. The Oventrop one looks like a bona fide throttling valve, if you can find it...0
- 86.7K THE MAIN WALL
- 56 Biomass
- 105 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 159 Indoor-Air Quality
- 69 Pipe Deterioration
- 948 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
