rehau to wirsboro
ecletrical
Member Posts: 22
This question was asked but never answered.
I came across 1" Rehau Raupex that I have to hook onto. I've never use it so have no tools. I use Q&E wirsboro fittings. Any suggestions for getting some fitting (insert?) that will be permanent onto the Raupex without their tool.
just about...
anything will "work"... rehau is pex A so the expansion fittings will attach fine. Is this heat or water? I have even used the standard pex crimp fittings in a pinch.0 -
Raupex will work with a Q&E expander??
It's a dhw line.
Are you saying that a wirsboro quick and easy fitting, using the expander tool, will fit the raupex?0 -
it pexA
so it should.... now does Rehau "approve"... ???0
- 114 Geothermal
