burner keeps going out on safty evry 5to 6 hours
need help burner keeps going out on safety every 5 to 6 hours
  • icesailor
    icesailor Posts: 7,260
    Keeps going out:
    Slo is right.
    Additionally, when the burner is getting ready to go out, goes it whine a lot? does it sound different after it is running for some time than after you reset it?
    It needs service. You shouldn't be hitting the reset button. Call a service person. If it is a plugged filter, you are damageing the fuel pump.
  • still going out
    its a beckette  i changed filter, screan ,new nosel cad cell and prim.control still is doing it but once a day to every 38 hours wound if its crap fuel
  • billtwocase
    billtwocase Posts: 2,384
    could be anything
    from simple adjustments, to motor, control, puff switch if equipped, fan prover if power vented, pump and or coupling, transformer and or electrodes, resistor if older delayed oil valve, plugged/restricted oil supply-line, etc. Could be a lot of possibilities. Best to call a tech to check it out.
