tighter home, colder rooms
Irv
Member Posts: 95
Changed all the windows in the house. My thermostat seems to shut off faster due to lower heat loss. As a result, the upstairs is cooler. Any suggestions?
new windows-cold rooms
if you can relocate your thermostat [or it's sensor], that might help. you could set the temperature down a bit to avoid boiling the warmer rooms, or use trv's on the rads there.
is your thermostat properly adjusted-anticipator etc?--nbc0
- 120 Geothermal
- 169 Indoor-Air Quality
