Piping Diagram for Radiant / Domestic Hot Water instantaneous
RadDude
Member Posts: 1
Does anyone have a diagram on a system that uses an instantaneous water heater for domestic hot water delivery to the home and has some radiant capability? The radiant part of this job would be for two small bathrooms only. Thank you
skip it
use a laing heater/pump combo or something similar instead. cheaper and better.Rob Brown
Designer for Rockport Mechanical
in beautiful Rockport Maine.0 -
Here ya go
Knock yourself out. Just make sure you read the warranty for the unit you choose. Don't recommend what you want to do but you should atleast pipe it properly if you choose to do so.
http://www.noritz.com/professionals/support/manual/2010_plumbing_diagrams/There was an error rendering this rich post.
- 87.4K THE MAIN WALL
- 167 Indoor-Air Quality
