Why is this baseboard radiator not getting hot?
Joseph_4
Member Posts: 319
Someone has a baseboard radiator. On the bottom of the radiator, on the right side, the supply pipe comes up through the floor, goes through the element of the radiator, then disappears back down through the floor. Only the right side under the element gets hot, nothing else. I think it's a monoflow system, but I'm not sure. There are no bleeders in the baseboard. Can someone tell me what the problem is?
your answer is in your question.
I think it's a monoflow system, but I'm not sure. There are no bleeders in the baseboard.Cost is what you spend , value is what you get.
cell # 413-841-6726
BASEBOARD NOT GETTING HOT
TRY BLEEDING THE SYSTEM FROM THE BOILER WITH AT LEAST 25 PSI0
- 87.4K THE MAIN WALL
- 167 Indoor-Air Quality
