Need a TigerLoop
Seth_5
Member Posts: 58
Hi Guys,
My TigerLoop is starting to leak. I am having problems finding one. I do not know of any supply houses around where I live so I looked some up online, and I cannot find any stores with online ordering. I found some on eBay, but they are not the same psi. The one I have now is a 10psi. The one I found on eBay is an 8 PSI. Does that matter? I have an old GE boiler with a Becket gun that fires down.
To learn more about this professional, click here to visit their ad in Find A Contractor.0
Hi Robert
Thanks Robert, Those are the ones I saw on ebay. Patriot Supply is on ebay too. The thing I was wondering is that some websites say max 10psi and some say 8psi for the same model. Does it really matter do you know? Thanks Again0 -
They are
used in lift situations,under a vacuum,not pressure. If you have pressure on the inlet,it's gravity and you don't need a tigerloop,with very rare exceptions,a Buderus G125 for example.To learn more about this professional, click here to visit their ad in Find A Contractor.0 -
I have
one and its leaking. I dont want to change anything, I just want to replace it. Its been there for a while as I can see its pretty old. It has posted on the side of it "10psi Max". So I was looking for one that was the same, but I could only find 8psi. So are you saying that it doesnt matter then? I would think it doesnt matter since I can't, for my life, even find one with 10psi.0
- 86K THE MAIN WALL
- 52 Biomass
- 421 Carbon Monoxide Awareness
- 81 Chimneys & Flues
- 5.3K Gas Heating
- 96 Geothermal
- 154 Indoor-Air Quality
- 3.3K Oil Heating
- 60 Pipe Deterioration
- 892 Plumbing
- 5.9K Radiant Heating
- 379 Solar
- 14.7K Strictly Steam
- 52 Water Quality
- 41 Industry Classes
