y strainer
are they really necessary??
    hot_rod Member Posts: 26,579
    what's in your system?
    The strainer can protect the boiler, valves and any component in the system from dirt and debris. older cast iron radiation systems are a good application.
    Also consider a dirt separator. They work to a smaller particle size and do not reduce the flow like a strainer does are it catches debris in the fluid stream.
    This slide shows how a strainer and a dirt separator work.
    I will be presenting a 1 hour dirt and air webinar for the RPA tomorrow at 7:00 CST.
    hr
